Why does smoke detector chirp when battery removed
Smoke detector chirps after battery removed
Saltpipe against snoring
When to use: In the event of a cold, Snoring, asthma, smoker's cough, pollen and other allergies, clogged bronchi, normal flu, etc. What does the SaltPipe ™ do? The micro-fine salt particles mix with the moist breath and so flows into the respiratory system where it loosens the stuck mucus and without any
