Honeywell Sensor; 4.5 to 9 VDC; 4 mA; -40 to ? degC; Quick Connect, 55SS16
Sensor; 4.5 to 9 VDC; 4 mA; -40 to ? degC; Quick Connect, Honeywell, MPN: 55SS16
The KEYBOT robot is based on easy-to-use and flexible open-source Arduino platform KEYBOT control board comes with the RJ11 plug, so it is very easy to connect other sensor modules with only one cable The robot is designed in metal structure, solid and durable. The assembly is really simple, believing you can install well the KEYBOT within 30mins As for the KEYBOT coding, you will learn how to get started with Arduino programming C language and Mixly block platform. Even the beginner with no coding experience can easily understand the graphical program Take your brain on an inspiring journey through the world of programming. Get started now
SENSOR, ULTRASONIC, ANALOG, CYLINDRICAL, SENSING RANGE 110-1000MM, Pepperl + Fuchs, MPN: UB1000-18GM75-I-V15
Sensor, Ultrasonic, Opposed Mode Emitter,, Banner Engineering, MPN: T186UEQ
SENSOR, ULTRASONIC, PROXIMITY, DISCRETE, 18MM CYLINDRICAL, Pepperl + Fuchs, MPN: UB300-18GM40-U-V1
Sensor,Ultrasonic,300mm max range,on/off,NPN output,sonic emission, Panasonic, MPN: US-N300
Accessoire Eglo Connect SENSOR Blanc, Détecteur de mouvement - Moderne - Extérieur - SENSOR - Délai de livraison moyen: 2 à 3 semaines. Port gratuit France métropolitaine et Belgique dès 100 €.
Shield MCU Arduino to Raspberry Pi Cœur du circuit : ATmega32u4, DFRobot, MPN: DFR0327
DETECTEUR INDUCTIF CYLINDRIQ M8 12 24V DC PNP NO 3FILS NOYABLE CONNECT M12 DEPO, Telemecanique Sensors, MPN: XS508B1PASA3
Sensor, Mini-style Quick Disconnect Cable, 4pin Female, strght connect, 2Meter, Banner Engineering, MPN: MBCC-406
OsiSense XS4 - détecteur inductif - M8 - L61mm - PPS - Sn 2.5mm - connect. 1/2p, Telemecanique Sensors, MPN: XS4P08MA230K
DETECTEUR INDUCTIF CYLINDRIQ M8 12 24V DC PNP NO 3FILS NOYABLE CONNECT M12 DEPO, Telemecanique Sensors, MPN: XS508B1PAL20M12
OsiSense XS4 - détecteur inductif - M18 - L73.5mm - PPS - Sn 8mm - connect. 7/8p, Telemecanique Sensors, MPN: XS4P18MA230A
OsiSense XS4 - détecteur inductif - M8 - L61mm - PPS - Sn 2.5mm - connect.1/2p, Telemecanique Sensors, MPN: XS4P08MB230K
OsiSense XS4 - détecteur inductif - M30 - L75mm - PPS - Sn 15mm - connect. 7/8p, Telemecanique Sensors, MPN: XS4P30MA230A
FOURCHE ASCENCEUR CONNECT LD, Telemecanique Sensors, MPN: XUVH0312LD
WC à poser en porcelaine sanitaire vitrifiée de couleur blanche.La porcelaine cuite à 1270°, est insensible à la lumière et inaltérable aux acides de base. Sa porosité est inférieure à 0,1%, le point de rupture se situe entre 500 et 600Kg/cm2. L?émail (épa
Plomberie sanitaire chauffage WC et accessoire WC WC à poser IDEAL STANDARD, WC à poser en porcelaine sanitaire vitrifiée de couleur blanche. La porcelaine cuite à 1270°, est insensible à la lumière et inaltérable aux acides de base. Sa porosité est inférieure à 0,1%, le point de rupture se
Pushbutton; Panel; 24 V; 0.4 to 3 A; DPDT; Solder/Quick-Connect; 0.5 to 250 VAC, Honeywell, MPN: AML22CBX2AC
Relay; 25 A (Nom.); 240 VAC; Solid-State; 24 to 280 VAC; Quick-Connect; 1 VAC, Opto 22, MPN: 240D25
Circuit Breaker; 10 A; 220 to 240 V; Quick-Connect; -10 degC; degC; 3.6 mm, Schurter, MPN: 4430.2298
Relay; 25 A (Nom.); 240 VAC; Solid-State; 24 to 280 VAC; Quick-Connect; 10 VAC, Opto 22, MPN: 240A25
Circuit Breaker; 2 A; 220 to 240 V; Quick-Connect; -10 degC; degC; 3.6 mm, Schurter, MPN: 4430.2296
Circuit Breaker; 20 A; 220 to 240 V; Quick-Connect; -10 degC; degC; 3.6 mm, Schurter, MPN: 4430.2306
Circuit Breaker; 5 A; 220 to 240 V; Quick-Connect; -10 degC; degC; 3.6 mm, Schurter, MPN: 4430.2303
Circuit Breaker; 10 A; 220 to 240 V; Quick-Connect; -10 degC; degC; 3.6 mm, Schurter, MPN: 4430.2304
Circuit Breaker; 15 A; 220 to 240 V; Quick-Connect; -10 degC; degC; 3.6 mm, Schurter, MPN: 4430.2305
cable assembly,plastic circular usb-b jam nut receptacle w/cord to 5-pin connect, Amphenol, MPN: USBBF7
Relay; 25 A (Nom.); 120 VAC; Solid-State; 12 to 140 VAC; Quick-Connect; 10 VAC, Opto 22, MPN: 120A25
Relay; 10 A; 1 to 10 Sec.; Quick-Connect/Solder; Time Delay; DPDT; Resistor, TE Connectivity, MPN: CLF-41-70010
Relay; 25 A (Nom.); 120 VAC; Solid-State; 12 to 140 VAC; Quick-Connect; 1 VAC, Opto 22, MPN: 120D25
Socket; Quick Connect; 1 to 3; Potter and Brumfield Brand, TE Connectivity, MPN: 27E396
Pushbutton; Panel; 0.01 to 0.1 A @ 0.5 to 24 VDC; SPDT; Solder/Quick-Connect, Honeywell, MPN: AML21BBA2BA
Cable to connect logic channels,DAS240 Type d'accessoire : Cordon de brassage pour canaux logiques A utiliser avec : Enregistreur de données DAS240, Sefram, MPN: 902407000
Circuit Breaker; 15 A; 220 to 240 V; Quick-Connect; -10 degC; degC; 3.6 mm, Schurter, MPN: 4430.2299
Circuit Breaker; 5 A; 220 to 240 V; Quick-Connect; -10 degC; degC; 3.6 mm, Schurter, MPN: 4430.2297
Relay; 10 A; 1.2 to 120 Sec.; Quick-Connect/Solder; Time Delay; DPDT; Knob, TE Connectivity, MPN: CLB-51-70120
Circuit Breaker; 20 A; 220 to 240 V; Quick-Connect; -10 degC; degC; 3.6 mm, Schurter, MPN: 4430.2300
Relay; 10 A; 1 to 10 Sec.; Quick-Connect/Solder; Time Delay; DPDT; Knob, TE Connectivity, MPN: CUB-51-70010
TEMPERATURE MODULE; 3 INPUTS TO CONNECT, Siemens, MPN: 3UF7700-1AA00-0
Sensor; Linear Motion; + 0.70%; 1 in.; 1.1 in.; 1.0 to 12.0 Kilohms; + 20 %, Sensata / BEI Sensors, MPN: 601R1KL.7
Sensor; Linear Motion; + 0.08%; 12 in.; 12.1 in.; 1.0 to 12.0 Kilohms; + 20 %, Sensata / BEI Sensors, MPN: 612R12KL.08
Sensor, Inductive; M12 x 1; 10 to 30 VDC; 200 mA (Max.); 2000 Hz; Brass, Turck Banner, MPN: NI8U-M12-AN6X-H1141
Sensor; 1.2 to 11.8 in.; 10 to 30 VDC; S18U Series, Banner Engineering, MPN: S18UUA
Sensor; Inductive Sensing Mode; NO 3-Wire DC Self-Contained; 5; 10 to 30 VDC, Turck Banner, MPN: BI5-Q08-AN6X2-V1131
Sensor; 175 VDC (Max.) (Switching); 0.5 A (Max.) (Switching); -40 to 105 degC, ZF, MPN: MP201801
Accessory; Cylindrical sensor; 67 mm H; 360 deg; 5 to 30 mm Diameter, Sensor, Pepperl + Fuchs, MPN: BF5-30
Sensor, Inductive; M12 x 1; 10 to 30 VDC; 150 mA (Max.); Shielded; -25 degC, Turck Banner, MPN: BI1.5-EG08-AN6X-H1341
Sensor; Retroreflective Sensing Mode; Multi-Beam; 6 in. to 30; 1 ms; Red LED, Banner Engineering, MPN: SBLV1
Sensor; NPN (Light Operate); Photoelectric; LED; 10 to 30 VDC; 1 ms; Glass, Banner Engineering, MPN: VS3AN5XLP
Sensor, Photoelectric; 1 SPDT Relay; Photoelectric; 0 to 12 m; Visible Red LED, Pepperl + Fuchs, MPN: RLK28-55/31/116
Sensor, Inductive; M12 x 1; 10 to 65 VDC; 100 mA (Max.); CPB (Housing), Turck Banner, MPN: NI4-M12-AD4X
Sensor; Sink; 40.0 mT (400) (Typ.); 4.5 to 24.0 VDC; 18 mA (Max.) @ 25 degC, Honeywell, MPN: SR3F-A1
Capteur de température IST INNOVATIVE SENSOR TECHNOLOGY, -50 → +150 °C TO-92 3-Pin Type de sortie : Numérique Précision : ±0.3°C Type de montage : Traversant Température de fonctionnement minimum : -50 °C Tension d'alimentation de fonctionnement minimum : 3 V Tension d'alimentation fonctionnement maximum : 5
PRESS SWITCH:22 TO 300 BAR DIN, Telemecanique Sensors, MPN: XMLB300D2C11
Sensor; 12 mm; 10 to 30 VDC; 200 mA (Max.); Inductive; CPB (Housing);, Turck Banner, MPN: BI3U-M12-AN6X-H1141
Sensor; Photoelectric; Opposed Sensing Mode; 66 ft.; 10 to 30 VDC; 6.5 ft., Banner Engineering, MPN: S186EQ
Temperature sensor, -40 to +125 degC, Microchip, MPN: MCP9700T-E/LT
Sensor; Diffuse Mode Sensing Mode; Photoelectric; 12 in.; LED; -40 to degC, Banner Engineering, MPN: SBD1
Sensor; Inductive Sensing Mode; 4-Wire DC PNP; 7; 10 to 30 VDC; 200 mA (Max.), Turck Banner, MPN: BI7-Q08-VP6X2
Sensor, Inductive; M8 x 1; 10 to 30 VDC; 150 mA (Max.) (Operating);, Turck Banner, MPN: BI1.5U-EG08-AN6X-V1131
Sensor, Retroreflective; NPN; Photoelectric; 79; Yellow LED; 10 to 30 VDC; 3 ms, Banner Engineering, MPN: S18SN6LPQ
Sensor, Inductive; M18 x 1; 20 to 250 VAC/20 to 320 VDC; Shielded; 60 Hz, Turck Banner, MPN: BI5U-G18-ADZ30X2-B1331
Sensor, Inductive; M12 x 1; 10 to 30 VDC; 200 mA (Max.); 500 Hz; Brass, Turck Banner, MPN: NI15-M30-AN6X-H1141
Sensor, Proximity; M18 x 1; 10 to 30 VDC; 15 mA (Max.); 500 Hz; Brass;, Pepperl + Fuchs, MPN: NBN8-18GM50-E2-V1
Sensor; 175 VDC (Max.) (Switching); 0.5 A (Max.); -40 to 105 degC; Aluminum, ZF, MPN: MP200701
PRESS SWITCH:20 TO 300 BAR DIN, Telemecanique Sensors, MPN: XMLA300D2C11
Sensor; Inductive Sensing Mode; N.O. and N.C; 40; 20 to 250 VAC; Rectangular, Pepperl + Fuchs, MPN: NJ40+U4+W
0 to 15 psia Precision Temp Compensated Sensor, Honeywell, MPN: SCX15AN
pressure trans XMLG 0 to 1 barG1, Telemecanique Sensors, MPN: XMLG001D21
SENSOR,HIGH VERSION,-100.0 TO +100KPA LOW-PRESSURE TYPE,M5 FEMALE + NPT1/8 MALE, Panasonic, MPN: DP-101A-N
Sensor, Inductive; M18 x 1; 20 to 250 VAC/10 to 300 VDC; 60 Hz; Brass;, Turck Banner, MPN: NI14-G18-ADZ30X2-B3331
TO-220 SERIAL DIGITAL THERMAL SENSOR (DEFAULT ADDRESS), Microchip, MPN: TC74A5-5.0VAT
Sensor, Pressure, Vacuum, Amplified, 0 PIS to -15.0 PSI, Honeywell, MPN: 40PC015V2A
Sensor, Inductive; M12 x 1; 10 to 30 VDC; 200 mA (Max.); Shielded; Brass, Turck Banner, MPN: BI5U-M18-AP6X-H1141
Sensor, Capacitive, Range 20mm, N.O. Output- 20 to 250vAC, Pepperl + Fuchs, MPN: CJ10-30GK-WS
SENSOR, HIGH RESOLUTION, 2 PIN CONN, 910 TO 1200 COIL RESISTANCE, 300 OUTPUT VOL, Honeywell, MPN: 3045A
Sensor, Inductive; M12 x 1; 10 to 30 VDC; 150 mA (Max.); Shielded; -25 degC, Turck Banner, MPN: BI1.5-EG08-AP6X-H1341
SENSOR,HIGH VERSION,-0.100 TO +1.000MPA HIGH-PRESSURE TYPE,M5 FEMALE + NPT1/8 MA, Panasonic, MPN: DP-102A-N
Sensor; Inductive Sensing Mode; 30 mm; NPN; 15 mm; 10 to 30 VDC; 200 mA (Max.), Turck Banner, MPN: BI15-M30-AN6X-H1141
Sensor, Inductive; M12 x 1; 10 to 30 VDC; 200 mA (Max.); 3000 Hz; Brass, Turck Banner, MPN: BI3U-M12-AN6X
Sensor, Inductive; M12 x 1; 10 to 30 VDC; 200 mA (Max.) (Load); 70 degC;, Turck Banner, MPN: NI20U-M30-AP6X-H1141
Sensor; Photoelectric; 4 in.; 20 to 250 VAC; 6.5 in., 4-Pin Micro Style QD, Banner Engineering, MPN: S18AW3FF100
Sensor; NPN (Dark Operate); Photoelectric; LED; 10 to 30 VDC; 1 ms; Glass, Banner Engineering, MPN: VS3RN5XLP
Sensor; M5 x 0.5; 10 to 30 VDC; 100 mA (Max.); Inductive; SS (Housing);, Turck Banner, MPN: BI1-EG05-AN6X
Sensor; 12 mm; 10 to 30 VDC; 200 mA (Max.); Inductive; CPB (Housing);, Turck Banner, MPN: BI4-M12-VN6X-H1141
Sensor, Inductive; M12 x 1; 10 to 65 VDC; 100 mA (Max.); Shielded; Brass, Turck Banner, MPN: BI2-M12-AD4X-H1141
Sensor, Inductive; M12 x 1; 10 to 30 VDC; 200 mA (Max.) (Operating);, Turck Banner, MPN: NI5-G12-AP6X-H1141
Sensor, Inductive; M12 x 1; 10 to 30 VDC; 200 mA (Max.); 500 Hz; Brass, Turck Banner, MPN: NI20-M30-AP6X-H1141
Sensor; Inductive Sensing Mode; 4-Wire DC PNP; 50; 10 to 65 VDC; 200 mA (Max.), Turck Banner, MPN: BI50U-Q80-VP4X2-H1141
Sensor; Inductive Sensing Mode; NPN; 10 mm; 10 to 30 VDC; 200 mA (Max.);, Turck Banner, MPN: BI10U-M30-AN6X-H1141
Capteur de température IST INNOVATIVE SENSOR TECHNOLOGY, -50 → +150 °C TO-92 3-Pin Type de sortie : Analogique Précision : ±0.3°C Type de montage : Traversant Température de fonctionnement minimum : -50 °C Tension d'alimentation de fonctionnement minimum : 3 V Tension d'alimentation fonctionnement maximum : 5
Sensor; Photoelectric; Opposed Sensing Mode; 66 ft.; 20 to 250 VAC; 6.5 ft., Banner Engineering, MPN: S183E
Sensor; Inductive Sensing Mode; 10 mm; 10 to 65 VDC; 100 mA (Max.); CPB, Turck Banner, MPN: BI10-M30-AD4X-H1141
Sensor; Inductive Sensing Mode; 1 NO/1 NC; 5; 10 to 30 VDC; 150 mA (Max.); PBT, Turck Banner, MPN: BI5-Q08-VP6X2
Sensor, Inductive; M12 x 1; 10 to 30 VDC; 200 mA (Max.) (Operating);, Turck Banner, MPN: BI2-G12-AN6X-H1141
Sensor; Opposed Sensing Mode; NPN (Sinking); 4 m; 10 to 30 VDC; 2 m; CE Marked, Banner Engineering, MPN: QS12VN6R
Sensor; M12-1; Sink; 4.5 to 24 VDC; 6 mA (Max.); 700 mV (Max.) (Saturation), ZF, MPN: GS100102
